SIEMENS 840D
SIEMENS 840D
DGavin0077
SIEMENS 840D
DGavin0077
is their a way to force cycle 800 even if it's not a multi axis tool path?
serge.quiblier
Hi @DGavin0077
yes it's possible.
You will have to edit the post processor and make two changes in the post.
The first change is addition a bit of code in the defineWorkplane function.
Please note that some lines of code had been hidden to reduce the amount of code shown.
function defineWorkPlane(_section, _setWorkPlane) {
  var abc = new Vector(0, 0, 0);
  cancelTransformation();
  if (!is3D() || machineConfiguration.isMultiAxisConfiguration()) { // use 5-axis indexing for multi-axis mode
    // set working plane after datum shift
    if (_section.isMultiAxis()) {
// Hiding some code for concise display
        setWorkPlane(abc, true); // turn
  } else { // pure 3D
    var remaining = _section.workPlane;
    if (!isSameDirection(remaining.forward, new Vector(0, 0, 1))) {
      error(localize("Tool orientation is not supported."));
      return abc;
    setRotation(remaining);
    setWorkPlane(abc, true); // ADSK Added to force TWP in 3 axis
  if (currentSection && (currentSection.getId() == _section.getId())) {
    operationSupportsTCP = (_section.isMultiAxis() || !useMultiAxisFeatures) && _section.getOptimizedTCPMode() == OPTIMIZE_NONE;
  return abc;
The code displayed on line 23 is the addition. The rest of the lines are here for reference.
You can either delete, or comment some lines at the start of the setWorkPlane function
function setWorkPlane(abc, turn) {
  if (is3D() && !machineConfiguration.isMultiAxisConfiguration()) {
    return; // ignore
  if (!((currentWorkPlaneABC == undefined) ||
        abcFormat.areDifferent(abc.x, currentWorkPlaneABC.x) ||
        abcFormat.areDifferent(abc.y, currentWorkPlaneABC.y) ||
        abcFormat.areDifferent(abc.z, currentWorkPlaneABC.z) ||
        (!currentWorkPlaneABCTurned && turn))) {
    return; // no change
..... rest of the function
Lines 3 to 7 are the ones that need to be deleted, or commented.
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
