Fusion Manufacture
Siemens 840D post issue "SAFE_TC" replaces "G0 SUPA Z0" - Hermle C42 Siemens 840D
4 REPLIES 4
tony3W49B
225 Views, 4 Replies
I'm here again, asking for help with a post processor.😀
I have attached my post to this. When I post this I get "G0 SUPA Z0" which is in the post options. There is also G28 & G53. However, my machine requires "SAFE_TC" instead.
Any of your very clever people any ideas as to where the post can be edited to post out "SAFE_TC", please.
I have managed to take this post from a 3 axis post to a 5 axis post, which for me is excellent. This is just causing me an issue.
I have tried copy, and overwriting the line {title:"SUPA", id:"SUPA"} with {title:"SAFE_TC", id:"SAFE_TC"} but this didn't work. The post properties still had the original options and still posted as per the option I chose below:-
Any help is very much appreciated, as always.
Thanks in advance
4 REPLIES 4
serge.quiblier
in reply to: tony3W49B
Hello @tony3W49B
Adding a sub value to the property safePositionMethod is the way to go.
But it won't suffice.
Magic does not exists in posts, so, a little sweat is also necessary.
Go down in the writeRetract function near the end of your post.
And notice that piece of code :
    switch (method) {
    case "G28":
      gMotionModal.reset();
      gAbsIncModal.reset();
      writeBlock(gFormat.format(28), gAbsIncModal.format(91), words);
      writeBlock(gAbsIncModal.format(90));
      break;
    case "G53":
      writeBlock(gAbsIncModal.format(90), gFormat.format(53), words, dFormat.format(0)); // retract
      if (lengthOffset != 0) {
        writeBlock(dFormat.format(lengthOffset));
      break;
    case "SUPA":
      writeBlock(gMotionModal.format(0), "SUPA", words, dFormat.format(0)); // retract
      break;
    default:
      error(localize("Unsupported safe position method."));
      return;
You can then edit it, to handle your new option:
    switch (method) {
    case "G28":
      break;
    case "G53":
      break;
    case "SUPA":
      break;
    case "SAFE_TC":
      writeBlock("SAFE_TC"); // retract
      break;
    default:
      return;
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
tony3W49B
in reply to: serge.quiblier
@serge.quiblier
Thanks for your response. After carrying out your instructions, :-
switch (method) {
case "G28":
break;
case "G53":
break;
case "SUPA":
break;
case "SAFE_TC":
break;
default:
return;
I still get the below:-
I've dropped down the safe retracts box and the "SAFE_TC" option is not there.
Code below:-
N13 G71
N14 G64
N15 G17
N16 G0 SUPA Z0 D0
N17 CYCLE800(1,"",0,27,0,0,0,0,0,0,0,0,0,0)
N18 ; HIGHFEED ROUGH BOSS
N19 T1 D1
N20 M6
N21 ; TXSW09M050B22.0R07 SWMT0904ZER-MM AH130
N22 S764 M3
serge.quiblier
Hi @tony3W49B
Have you changed the property definition?
Initial code:
  safePositionMethod: {
    title      : "Safe Retracts",
    description: "Select your desired retract option. 'Clearance Height' retracts to the operation clearance height.",
    group      : "homePositions",
    type       : "enum",
    values     : [
      // {title: "G28", id: "G28"},
      {title:"G53", id:"G53"},
      {title:"Clearance Height", id:"clearanceHeight"},
    value: "SUPA",
    scope: "post"
New code
    type       : "enum",
    values     : [
      {title:"SUPA", id:"SUPA"},  // Adding a comma at the end of the line
      {title:"SAFE_TC", id:"SAFE_TC"},  // Adding the newest option
    value: "SAFE_TC",  // Changing the default value to the newest option
    scope: "post"
Regards.
Serge.Q
cam.autodesk.com
tony3W49B
@serge.quiblier
You are a genius!!!!!
Thanks for your help!
Superstar.
