SIEMENS 828D POST PROCESSOR TURNING
Hi guys, recently purchased a XYZ TC320 LTY with a siemens 828d control like our mill, was wondering wether anyone had a post processor for the 828d control, or had adjusted an existing post processor that works well with the 828d?
Thanks James
boopathi.sivakumar
@Anonymous
Here is the generic post for the Siemens sinumeric 840D which almost have same functionality of sinumeric 828D.
https://cam.autodesk.com/hsmposts?p=siemens-840d
If you require any minor post modifications you have separate forum to solve your queries
You can check this post out first and if you need any mods or queries related to post processor you can post out in this forum
hsm-post-processor-forum
Boopathi Sivakumar
Senior Technology Consultant
The guy asked for a turning post procesor and you gave him a milling one. Which doesn't work at gall with lathe.
boopathi.sivakumar
Hi @Anonymous  Thanks for pointing that out. I didn't realize that I have shared the wrong post back then in 2019. https://cam.autodesk.com/hsmposts?p=siemens_mill-turn
This one is the generic mill turn post. which might need some modification.
Boopathi Sivakumar
