Fusion Manufacture
ShopBot Post Processor
6 REPLIES 6
SGoldthwaite
2046 Views, 6 Replies
I was using the ShopBot at my makerspace (it's been a while since I've used it).   I downloaded the latest ShopBot (openSBP) post processor (ver 42961)  from https://cam.autodesk.com/hsmposts
When I tried to run the ShopBot, it was acting very strange.  The spindle would not turn on.  If I continued (I removed the end mill), the z-position on the display changed by a couple inches without the z-axis physically moving. Then it seemed to move properly (but at the wrong z height)  At the end I'd get an error "Not enough axes designated to update all locations..."
The ShopBot control software is v3.8.42 (running on Windows 10).  When I go to create the post in Fusion, there's a property window in the dialog box.  First property says "SB3 V3.6 or greater".  I had this set to "yes" because I'm running v3.8.  But I decided to set it to "No" just to see what happens.  Now everything works fine.
Tags (1)
Labels (1)
6 REPLIES 6
daxpatel45
in reply to: SGoldthwaite
Maybe Issue with Shopbot software and Fusion Processor. Need to downgrade Shopbot Control Software.
Hope it works.
SGoldthwaite
It works fine when  "SB3 V3.6 or greater" is set to "No".  It's just that something appears to be wrong with this property in the post processor.
aokere
Hi, can you point me to where this setting is? "SB3 V3.6 or greater"- I can't find it. The spindle of the Shopbot I'm using is also not turning on.
CNC_Lee
@aokere
You can find this setting under the Configuration drop-down within the Post properties section of the NC Program dialog box as shown in the pic below:
If my post answers your question, please use Accept as Solution.
CNC Lee
Fusion 360 CAM Post Processor Expert
https://linktr.ee/cnclee
aokere
in reply to: CNC_Lee
I don't have a configuration drop down menu in my NC program dialogue box. Do you know the reason for this/how I can make it show up?
edit: nevermind, I selected "Shopbot Open SBP" as my post instead of Shopbot ISO and the configuration menu showed up. Thank you
CNC_Lee
@aokere
It is not available with that post processor. That is also a deprecated post and you will want to select the Shopbot OpenSBP post from the Fusion Post Library.
CNC Lee
