Fusion Manufacture
Setup sheet with units in inches
2 REPLIES 2
micro44
268 Views, 2 Replies
Is it possible to have a setup sheet display tools and board dimensions in inches even though the document is in mm?
I do most of the design work in inches and then change to mm for the post processing. My cnc needs to have the units in mm.
2 REPLIES 2
djlunty
in reply to: micro44
Does your post processor have an option to create the g-code file in millimeters?  I design in inches and output in mm using the RS-274D post processor.   Setup Sheets are in inches.
Unit         Millimeters
Doug
seth.madore
What @djlunty suggests is correct. To my knowledge, almost all the machine post processors support IN/MM formats, so you can have your entire document in Imperial, but post your code out in MM
Seth Madore
