Fusion Manufacture
Setup part position and generated Post file
1 REPLY 1
daviddoruch
66 Views, 1 Reply
I can't seem to figure out how to get the generated GCode to reflect the part position.
I have selected the stock point and table attach point and adjusted X and Y distances to whatever number (say 4in).
The simulation shows the part properly offset by 4" from both X and Y but when I generate GCode the positions are not shifted by 4".
Am I missing something here?
Neither X or Y should every be negative with these settings.
1 REPLY 1
a.laasW8M6T
in reply to: daviddoruch
Hi
the part position on the machine has no influence on the output of the G-Code
It is for the correct visual representation during machine simulation.
If you want the origin to be on that location  you will need to create a sketch point that is 4 inches away in XY.
Then in your setup you select that point as your WCS location
