I'm running my first part using a 4th axis and learning as I go. But I'm stumped about setting Z zero to a part that is not on a horizontal plane. Do you set Z zero to the top of your material before or after rotating to the machining orientation? Or is there another method that I'm not thinking about? I did a quick forum search but didn't find anything on this. I realize I could pick an arbitrary point anywhere above the material but I need to control the depth of the hole in relation to the top horizontal plane. See the Shaft Hole Ops setup in the attached file.
