Fusion Manufacture
Setting up Slitting Saw
14 REPLIES 14
Message 1 of 15
jeph_s22
355 Views, 14 Replies
Hello everyone.
First time using a slitting saw - can anyone help me out with setting this one up? I was thinking 0.125" doc on this one. Part attached.
Any help is appreciated.
14 REPLIES 14
Message 2 of 15
I made a few tests for you, attached for review.
Message 3 of 15
seth.madore
in reply to: jeph_s22
It depends, I suppose. What is the tool material and what is the material being cut? Do you have a stout machine, or do you need to baby it thru the cut?
Seth Madore
Message 4 of 15
jeph_s22
in reply to: seth.madore
Hi Seth,
Material being cut is 1045 and 1018 mild steel. Tool material is HSS. Machine is a Mori Sieki NL3000y, so enough machine for the job i would say.
Message 5 of 15
seth.madore
Yeah, the Mori is a stout machine. Personally, I would make an attempt at doing it in one shot (provided you've got a couple extra saws (just in case)
Also, if you're in the USA, both Harvey and Internal Tool make some carbide slitting saws in smaller diameters, you wouldn't need to go with a 4" HSS saw...
Seth Madore
Message 6 of 15
jeph_s22
I only got the one 4" HSS saw for this job. So taking it easy this time would probably be the way to go.
Message 7 of 15
seth.madore
Hmm. I'm never comfortable going into a job with only one tool at my disposal, but it's also easy for me to say as you're likely not the one making that judgement call.
I'd certainly reduce your feedrate. .001" per tooth is going to be quite aggressive. As an example, I run a 1.5" (12 teeth) saw in stainless at 600 RPM and 2.0 IPM. You're running at 57rpm and 2.0" IPM. I'd likely bump the speed up to 75sfpm and reduce the feed per tooth by about half. Depth of cut (in 3 passes) would be .150 per (although I think you could do this in one shot, just taking it slow and plenty of coolant)
Seth Madore
Message 8 of 15
programming2C78B
ours has more like 100teeth so we do .0001 cpt, 3x thickness as DOC, and about 50-75sfm in stainless. Everything works out on size. There are some great guide PDF's online if you just look into them.
Please click "Accept Solution" if what I wrote solved your issue!
Message 9 of 15
jeph_s22
@seth.madoreI do buy my own tools but was unsure what will work best for me so I just got one unit to try for a quick job. Are your saws carbide or hss?
I will try with the suggested feeds and speeds, thanks for your input on this.
@programming2C78BI actually did try looking up online but couldn't find much.
Message 10 of 15
seth.madore
Carbide, always carbide 🙂
(that's not entirely true, there are times when I have to use a gigantic milling arbor and .50" wide x 4" dia HSS saw)
Seth Madore
Message 11 of 15
jeph_s22
at 0.0005 ipr and 75 sfm Fusion estimates a 3" cut, 4 passes to take 20 minutes. Does that sound accurate to you? sound like a long time.
Message 12 of 15
seth.madore
It's not .0005 ipr, but IPT (inches per tooth). It should be about a 12 min cycle
(which is also why I would prefer carbide and a single pass)
Seth Madore
Message 13 of 15
jeph_s22
Hi Seth,
I got the following error log when I try and output this code; can you tell me what this means?
Message 14 of 15
jeph_s22
Part again attached.
Message 15 of 15
CNC_Lee
@jeph_s22
 The toolpath could be out of the machine travel linits as defined in the machine configuration. It is a bit haed to tell without the post processor.
If my post answers your question, please use Accept as Solution.
CNC Lee
Fusion 360 CAM Post Processor Expert
https://linktr.ee/cnclee
