Announcements
Setting the Origin Point to a Predefined point on a machine model
glennX6CNF
glennX6CNF
I have a 5 axis machine where the WCS origin point has been preset at the B axis rotation point and cannot be changed. I was hoping there may be a way to define the WCS origin based on the machine model rather than the stock box.
Currently I have to make a cylinder or something and move it the correct distance away and then use that as the zeroing point.
It would be far more convenient (and accurate) if I could define the zero point in the machine configuration, and then I just have to use the attach points option to position the part. If there are any ways to do this, that would be amazing!
Thanks for your help!
a.laasW8M6T
Hi
You can create a Template file that has a setup the has the WCS set to Model Origin.
In Machine builder set the part attachment point where you want the WCS to be located.
In the setup for part position set it to selected point and don't make any selections.
You position the part using a Joint in the Design workspace
glennX6CNF
Thank you for the informative video! I think I understand the premise and I will give it a go now.
What is that parameters tab? And how do you move the vice automatically? Those both seem extremely useful!
a.laasW8M6T
Hi
The work holding template is based originally from this presentation by Rob Lockwood
https://www.autodesk.com/autodesk-university/class/Streamlining-CAM-Workflows-Templates-2019
Fusion has changed quite a bit since then but the fundamentals are the same
This is an up to date presentation from AU2024 which covers using Configurations
https://www.autodesk.com/autodesk-university/class/Templates-Configurations-and-Containers-for-Agile...
Give them a watch and then play around and come up with you own template for your Vices/Workholding
glennX6CNF
Thanks so much for your help! Hopefully I can get it all working smoothly now!
