Fusion Manufacture
select to use C-axis or xyz in programming
3 REPLIES 3
thierry924K4
98 Views, 3 Replies
Is it possible to select when to use the C axis and when to use XYZ
e.g. for 1 toolpath I want to do 3D milling with the C-axis and for the next I want to mill a quick opp. with XYZ
It would make life much more easy if this would be a simple checkbox in the toolpath setup
3 REPLIES 3
seth.madore
in reply to: thierry924K4
It's not a checkbox in a toolpath (yet), but can be handled by most post processors when you use the "usePolarMode" action.
Example:
Seth Madore
thierry924K4
in reply to: seth.madore
ok I see, did not know that and that is indeed very usefull
are there other commands like this that i can use? is there a list? 🙂
seth.madore
Consult your post processor, the supported commands will be listed at the top, as so:
Seth Madore
