Fusion Manufacture
Select same diameter bug
3 REPLIES 3
AaronRonda1
82 Views, 3 Replies
Select same diameter stopped working after the latest update. Pick the face of a bore and it generates a toolpath, click "select same diameter" and it won't work... you have to deselect same diameter and pick all the bores of the same diameter. Existing tool paths that worked perfectly before the update will no longer generate. Thanks for another bug filled update Fusion!
3 REPLIES 3
seth.madore
in reply to: AaronRonda1
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
I'm not seeing this issue on this sample part:
Seth Madore
AaronRonda1
in reply to: seth.madore
I cannot, they are proprietary parts and by contract cannot be shared. I've included a video showing just the features pertinent to the issue. This was an existing toolpath that would not regenerate unless I selected all the features I needed instead of selecting one and trying to use the same diameter feature.
seth.madore
Hmm, what about if you toggle the "Same Z Height" or the other options there?
Can you share your file privately? I'd really like to understand/replicate this issue. If so, you can email it to me directly and I will treat it as confidential (as we do all customer data that's shared thru back-channel means)
seth DOT madore AT autodesk DOT com
Seth Madore
