Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Select axis
10 REPLIES 10
Message 1 of 11
info
417 Views, 10 Replies
Select axis
I want to use a Yeti Tool cnc with Fusion 360.
In the documentation of the Yeti Tool, the axis are as follows:
Hope you guys can help me out!! Thanks!
Unfortunatelly, in the setup, I am unable to recreate this setup of axis. When I recreate the X and Y, the Z is upside down. When I flip it, the X or Y is not as it should be.
How to manage this?
I am running multiple machines, so changing the default set up of the axis will not work as it will break the way the other machines are set up.
Labels (4)
10 REPLIES 10
Message 2 of 11
seth.madore
in reply to: info
Does the Yeti have actual axis designations that correlate with the colors? So, Y is green, X is red, blue is Z?
Seth Madore
Message 3 of 11
info
in reply to: info
Yes.
Here is the document I referred to.
https://www.yetitool.com.au/wp-content/uploads/2020/03/Fusion-360-Workflow-Guide-Rev1.1.pdf
See page 5.
They use the Y as UP. But of course I use the Z
Message 4 of 11
seth.madore
in reply to: info
Right, but on page 20 of that document, we're shown this image:
Setting our WCS like this will give us the result you're looking for:
It appears that their documentation is skipping a few steps and images.
Seth Madore
Message 5 of 11
info
in reply to: info
So looking at these picture, their document is speak against itself? Because on page 4, home is set in the far left corner, but looking at the picture that you screenshotted, home is in the far right corner.
Message 6 of 11
smunzer8ZZFW
in reply to: info
Out of curiosity what does the WCS look like of the actual drawing of the part posted, is it upside down as well? if so that might be the issue, if you design in the UCS you want to use then you can just mimic it in the setup.
Message 7 of 11
seth.madore
in reply to: info
As I suggested towards the end of my last post; there are inaccuracies in the documentation. Do you have a user interface (computer control screen) that displays the axis? Looking over their website and videos, nothing is jumping out at me as "we do things backwards from industry standard" (in regards to axis designation)
Seth Madore
Message 8 of 11
info
in reply to: seth.madore
Thanks for your reply.
On the display of the machine, the axis are set as this image:
Therefore, I am trying to get Fusions axis the same way.
Message 9 of 11
seth.madore
in reply to: info
That image does not correlate to other images that they show in their own documentation.
Question; have you tried a simple program to observe what goes on?
-EDIT-
Their documentation refers to "Set Y axis along the long edge, and Z is pointing up"
Seth Madore
Message 10 of 11
seth.madore
in reply to: info
Seth Madore
Message 11 of 11
seth.madore
in reply to: info
Right off the bat; setting Orientation to "Model Orientation" is not very good instruction, as it assumes that you (or the person that created the model) designed it properly with manufacturing in mind (that it's been aligned the way you want to machine it). Hence, why they follow up with:
Seth Madore
Technology Administrators
