Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Second pass with offset - finishing strategy
2 REPLIES 2
dan3s2020
257 Views, 2 Replies
Hi ! I want to make a parallel strategy on a model and  be able to make a second pass with the same strategy but with an offset for the stepover in case i'm not satisfied with the result , to run this second pass to go over the scallops ,like starting with an offset of 0.5mm from the edge of the model. Is it possible?
*A few more  noob questions about feeds & speeds if it's allowed:
It's too fast to plunge with ~250mm/min and cut with 700mm/min feedrate in oak with a r0.25 tapered ball nose?
any advice for the rpm?
2 REPLIES 2
engineguy
in reply to: dan3s2020
@dan3s2020
Have you tried just using the "Additional Offset" under the "Geometry" tab set to 0.5 ??
That will make Fusion create the toolpath offset by the 0.5, may bo what you need, just a crude "workaround" 🙂
dan3s2020
in reply to: engineguy
oh, that really is a workaround .Thank you !
