Search function does not work
Hi All,
I'm Chris from The Netherlands. I am working with Fushion360 for quit a while now. Since the beginning I'm having troubles with the search function. Mostly I'm having the error lik in the picture below. Can somebody help me with this?
Thanks in advance.
Marco.Takx
Hi @Anonymous,
Hier @Marco.Takx from the Netherlands :winking_face:
See the topic here. It seems that more people have this issue.
But like the Autodesk employee said I also can't reproduce this.
I also don't know if this is specific a Mac issue.
I only work on Windows machines.
https://forums.autodesk.com/t5/fusion-360-support/search-is-broken/td-p/9385794
Maybe you can replay on this topic so all the information stay's in one place.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
matt.pooley
Hi @chrisBNEXZ,
We might have found a workaround for this issue while we work on a full fix. If you use the down arrow next to the search entry field and select 'All Data', and then run that search, it should initialize the system so that subsequent project searches work as expected. Unfortunately this workaround would need to be triggered once a day, but if it works for you please let us know so we can confirm that what we are planning to change will fix this fully.
Matt Pooley
On Behalf of the Fusion Dev Team
