Fusion Manufacture
Screw Cutting
3 REPLIES 3
neilC6X7Z
76 Views, 3 Replies
Screw Cutting
Screw Cutting
Hello all I have a question when cutting a thread on some tough material is it possible when in reduced infeed mode. The first cut is quite heavy. Is there a way to have the tool sit out more on the diameter other than using the offsets?
They are small parts but a coarse thread on it would be happy to let it run checking in on it periodically.  If I could just get the first pass to be a little liter.
Look forward to your thoughts.
Thanks, a bunch
3 REPLIES 3
Threadmill cycle? You can change the number of passes or even so far as duplicating it, adding stock to leave, and doing a "roughing" cut before.
you need to add more info on these posts.
Please click "Accept Solution" if what I wrote solved your issue!
oh Sorry its on a lathe i should of said that
oh sorry its on  a lathe i should of said that
