Fusion Manufacture
SAME PART--FINISH NEEDS TO GO LOWER--FILE ATTACHED
3 REPLIES 3
utekcnc
136 Views, 3 Replies
I need the blue ball nose path showed in the screenshot to wrap on down a bit.   How do I do that? TIA
3 REPLIES 3
TrollTuner2
in reply to: utekcnc
Containment / Machining Boundary  Give it a little more
HughesTooling
in reply to: TrollTuner2
The trouble with this sort of part is in one direction you want the containment to be centre but tool outside in the other direction. Only way is to draw a boundary extended by the rad of the currer. See attached file.
Mark Hughes
Owner, Hughes Tooling
engineguy
@utekcnc
Try enabling the option shown in the image below, should extend the toolpath at the ends, hope that helps.
