Running a tapping test on a Haas ST-10Y lathe, 309 Exceeded Max Feedrate error
Trying to run a rigid tap and I am getting an error and the lathe operation hangs? Error 309 Exceeded Max Feedrate.
M154 for engaging c axis?
Here is the posting:
O01001
G98 G18
G20
G50 S6000
M31
G53 G0 Y0.
G53 X0.
G53 Z0.
(Face2)
T606
M155
G99
M22
G97
S521 M3
G54
M8
G18
G0 Z0.1969
X2.2 Y0.
G50 S5000
G96
S300 M3
Z0.0366
X1.4
G1 X1.1131 F0.005
X1. Z-0.02
X-0.016
X0.0971 Z0.0366
G0 X2.2
Z0.1969
G97
S521 M3
M9
G53 Y0.
G53 X0.
G53 Z0.
(Drill5)
M1
T1212
M155
G99
G97
S3670 M3
G54
M8
G18
G0 Z0.6
X0. Y0.
Z0.2
G83 X0. Y0. Z-1.02 R0.18 Q0.0781 F0.0079
G80
G0 Z0.6
M9
G53 Y0.
G53 X0.
G53 Z0.
(Drill8)
M1
T505
M155
G99
G97
S500
G54
M8
G18
G0 Z0.6
X0. Y0.
Z0.2
G84 X0. Y0. Z-1.02 R0.18 F16.
G80
G0 Z0.6
M9
M33
G53 X0. Y0.
G53 Z0.
M5
M155
G53 G0 Y0.
M30
O01001
G98 G18
G20
G50 S6000
M31
G53 G0 Y0.
G53 X0.
G53 Z0.
(Face2)
T606
M155
G99
M22
G97
S521 M3
G54
M8
G18
G0 Z0.1969
X2.2 Y0.
G50 S5000
G96
S300 M3
Z0.0366
X1.4
G1 X1.1131 F0.005
X1. Z-0.02
X-0.016
X0.0971 Z0.0366
G0 X2.2
Z0.1969
G97
S521 M3
M9
G53 Y0.
G53 X0.
G53 Z0.
(Drill5)
M1
T1212
M155
G99
G97
S3670 M3
G54
M8
G18
G0 Z0.6
X0. Y0.
Z0.2
G80
G0 Z0.6
M9
G53 Y0.
G53 X0.
G53 Z0.
(Drill8)
M1
T505
M155
G99
G97
S500
G54
M8
G18
G0 Z0.6
X0. Y0.
Z0.2
G80
G0 Z0.6
M9
M33
G53 X0. Y0.
G53 Z0.
M5
M155
G53 G0 Y0.
M30
You are trying to drive tap at feed rate of 16 inches per revolution.
Just a wild guess here, if you are doing 16 pitch thread, your feed rate should be F.0625.
G99 is feed rate per revolution
if pitch is 16 threads per inch then , 1 divided by 16 = .0625
Ok Thanks! Ill adjust accordingly and let you know if this works.
I made a guess regarding 16 pitch thread, if that's not what you are doing adjust feed rate for actual thread pitch or you will break the tap.
Remember, it's 1 divided by pitch, you can have up to 5 decimal places feed rate in single point threading and taping.
dmealer
Looks like your federate is IPM....a haas needs inches per rev.
(copy of posted G-code)
T505
M155
G99 (feed per revolution)
G97
S500
G54
M8
G18
G0 Z0.6
X0. Y0.
Z0.2
G80
G0 Z0.6
M9
M33
G53 X0. Y0.
G53 Z0.
M5
M155
G53 G0 Y0.
M30
I don't see G98 anywhere in above code, do you?
His code also has G20, inch mode, so F16. in tapping cycle means 16 inches per revolution.
