run external script from fusion 360 post processor
Machining_RapidMade
Machining_RapidMade
Is there any way I can trigger an external script from with in my post processor, I've figured out how to write to an external file so I was wondering if there was a way to run a an external script.
ltomuta
This is sample code from setup-sheet.cps
function onTerminate() {
  //newOutput(); // Added by PA
  // add this to print automatically - you could print to XPS and PDF writer
  var device = "Microsoft XPS Document Writer";
  if (device) {
    executeNoWait("rundll32.exe", "mshtml.dll,PrintHTML " + quote(getOutputPath()) + quote(device), false, "");
  } else {
    executeNoWait("rundll32.exe", "mshtml.dll,PrintHTML " + quote(getOutputPath()), false, "");
Machining_RapidMade
awesome thank you!
