Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Router Bit Travel Speed
3 REPLIES 3
williamlFL
1151 Views, 3 Replies
Hello All,
How can I adjust the rate of speed when the bit is out of the material?
-Will
Tags (2)
3 REPLIES 3
LibertyMachine
in reply to: williamlFL
When it's out of the material, it should be feeding at G0 speed which is full rapid. Of course, that may vary depending on what your selections are as well as what post processor and machine you are using
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
williamlFL
in reply to: LibertyMachine
Thanks Seth.
xander.luciano
There's also this setting you can mess around with if you're daring.
xonoyzx
But like Seth said, mostly it's just the machine rapid between movements.
Best,
-Xander Luciano
Xander Luciano
CAM Content Developer
If my post is helpful, press the Kudo button - If it resolves your issue, press Accept as Solution!
Quick Tips: When to resselect CAM geometry | Understanding Smoothing in CAM | Adaptive Facing | Online GCode Viewer
