Fusion Manufacture
Rounding equations to 3 decimals
3 REPLIES 3
DarthBane55
204 Views, 3 Replies
How would I go about rounding an equation to 3 decimal places?
For example: (tool_diameter*0.013333)
If the tool is 0.5" diameter, this would result 0.006666666
But I want to use 0.007".
I just could not find a list of all the operators and whatnot that we can use in equations.
Thanks!
EDIT: I would also like to know if we can add  comments in equations.  I have a few funky equations and sometimes I'd like to edit them but can't remember exactly which constants do what.  If I could put myself a comment within the equation, it would be helpful.
3 REPLIES 3
Math.roundto(1.23456789in; 0.001in)
(Input1; Input2)
Input 1 is what ever expression you're evaluating and Input 2 is what decimal place you want to round to.
You need to specify units for both, you can see I put (Input1in; Input2in)
Dan Pacific
Product Manager - Fusion 360 Manufacturing
Thank you @daniel.pacific , that worked perfectly.
Since you marked your own answer as solved, could you answer the 2nd part of the question, about adding comments please?
Thanks again.
EDIT: actually, could you point me to an online document where they list all these functions?  Otherwise I'll have more and more questions regarding this as I am diving deeper in the equations now.  For example, now I'd like to know if we can do "if" statements and such.  Thanks!
Just making sure you saw it 😀
https://help.autodesk.com/view/fusion360/ENU/?guid=MFG-REF-EXPRESS
The help source above is a solid reference to expressions and the math functions.
Dan Pacific
