Fusion Manufacture
Roughing out a mitre prior to chamfering for MDF panels
2 REPLIES 2
simonwjsawyer
148 Views, 2 Replies
I've been using fusion for a couple of years now and i still can't figure out how to rough out a mitre prior to using the chamfer pass.
I do a lot of panel work and often want to mitre corners of sheet materials such as ply and MDF but sometimes do solid timbers too. I had been mitring on the router table but we've just got a tool changer so it makes sense to use a v bit to make the mitred corners.
https://a360.co/3ZfQPNE
Above is an example of what i'm cutting. Ideally I'd like to rough out the mitre with a flat and then do a finishing pass with a v bit. This is because the chamfer appears to be a finishing operation and one can't do multiple depths. cutting a full depth chamfer on timber can cause breakout as its removing a lot of material at once. I had a nightmare with a walnut tabletop that i was putting a hefty chamfer on...
Is it possible to rough out with a flat or a ball end? if so how? its driving me mad!!
thanks in advance
Labels (1)
2 REPLIES 2
seth.madore
in reply to: simonwjsawyer
Parallel or 3D Contour would be my choice:
Seth Madore
simonwjsawyer
in reply to: seth.madore
Hi Seth,
Thats great, thank you. worked like a charm!
best
simon
