Fusion Manufacture
ROUGHING OPS TAKING WAY TOO LONG
5 REPLIES 5
chadJP34D
155 Views, 5 Replies
Has anyone else been having issues with their roughing ops taking too long? Some of mine say they'll finish in 2billion minutes, as seen in the picture below.
I'm doing a turning or mill/turn.  It was only after a recent update that the time went up. I'm able to delete and redo the roughing op and it turns just fine. I'd like to find the issue to keep from having to delete and redo the roughing ops. Any help would be appreciated.
Attached is the .f3d.
Thanks in advance.
5 REPLIES 5
a.laasW8M6T
in reply to: chadJP34D
Hi
There is no file attached?
Somehow its probably got a really small feedrate put in
chadJP34D
shoot, how about now?
chadJP34D
I've been checking a small feed rate. It's .001" per rev at a rpm of 800.
a.laasW8M6T
seems to be an Issue with rest machining
If I turn it off and generate the toolpath it works fine
Then turn it on and it works fine too.
It wasn't actually generating a toolpath before
chadJP34D
Oh freak, go figure it was something simple like that. Thank you for pointing that out to me.
