Fusion Manufacture
Roughing of 2D contours
4 REPLIES 4
loveluckey
194 Views, 4 Replies
In 2D contour roughing, is there a function that removes only the specified value of the material sidewall regardless of the tool pie?
It's possible in Adaptive, but I'm asking because Contour doesn't seem to have the same function.
4 REPLIES 4
enable roughing passes, set the max stepover to what you would in the adaptive.
Please click "Accept Solution" if what I wrote solved your issue!
Marco.Takx
in reply to: loveluckey
Hi @loveluckey,
What @programming2C78B said is correct.
You can activate the Roughing Passes setting.
One tip. If you also select the Stock Contour that describes the Rough material, the toolpaths will automatically extend or cut off what is necessary.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Consultant
Then, if the side wall of the stock to be finally removed is 10 mm and the side wall is removed in 2 mm steps, should the stepover value be set to 2 mm and the number of steps to be set to 5 steps?
yes
