Fusion Manufacture
Rotary Tool Path Axis not perpendicular to tool
1 REPLY 1
kdee122
99 Views, 1 Reply
Is it possible to add a lean/tilt to the rotary tool path so the tool axis is not perpendicular to the axis of rotation?
Similar to this: https://www.instagram.com/p/CvN4hErgsdq/
1 REPLY 1
a.laasW8M6T
in reply to: kdee122
Yes you can do this in Fusion, but not really with the rotary toolpaths, they are designed more for 4 axis type machines
Probably the easiest way is with Steep and shallow, but you can use most of the other 3d toolpaths to achieve a similar result:
The trick is to use From curve or from point for the primary mode
and then use override tilt angle
Example file attached
