Fusion Manufacture
rotary pocket violates stepover amount
0 REPLIES 0
Message 1 of 1
programming2C78B
44 Views, 0 Replies
The two center lines are at x.8606 and x1.14 for a difference of .2794". The max stepover is called out as 0.2
If I callout a .1 stepover, then the paths are at .46, .56, .66, etc as they should.
If I callout a .18 stepover, then the paths are at .82 and 1.18 for a gap of .36!
the pocket is 1.46 wide around a 7.6 diameter, using a 3/8-1/16th bullnose.
What am I missing?
Please click "Accept Solution" if what I wrote solved your issue!
0 REPLIES 0
