Announcements
Rotary Chamfering a Square Shape
Natranzow
Natranzow
We have a piece of hardware, call it a box with rounded corners on an a-axis. Is there a way to chamfer the end of the box via some sort of multiaxis path? Rotary doesnt seem to allow a single line to be selected and multiaxis contour seems to require me to use some level of tilt.
Replies (8)
spencer.hardcastle
Hi @Natranzow ,
Thanks for posting! Would you be able to upload a sample file and i'll be happy to take a look at it for you.
Many thanks!
Spencer Hardcastle
Manager of Customer Advocacy - Autodesk Fusion
Natranzow
Ive uploaded an example file. For the sake of the example i've modeled the chamfers in the area i wish to chamfer and located the origin in the position the actual part is in. Thanks for taking a look. Apologies for the late reply.
Ketherton21
is your machine 4 axis? or 3+1?
engineguy
@Natranzow
You can create a single line toolpath in Rotary using "Circular" and placing both the "Front" and "Back" modes to the same position
Hope that helped a little :slightly_smiling_face:
Stay Safe
Regards
Rob
daniel_lyall
@Natranzow have a look at the attached model, it's close.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Natranzow
@spencer.hardcastle
Did you happen to look at the file yet? No solution posted has worked yet.
I preffer Blend over Flow because it gives more uniform pattern over curved surfaces.
engineguy
@Natranzow
Well, all I have is a very ugly workaround, about the ugliest I have ever seen but it does work if you want to try it out :slightly_smiling_face: :slightly_smiling_face: :slightly_smiling_face:
File attached.
Stay Safe
Regards
Rob
