Rotary Chamfering a Square Shape
Natranzow
Message 1 of 9
Natranzow
We have a piece of hardware, call it a box with rounded corners on an a-axis. Is there a way to chamfer the end of the box via some sort of multiaxis path? Rotary doesnt seem to allow a single line to be selected and multiaxis contour seems to require me to use some level of tilt.
Replies (8)
Message 2 of 9
spencer.hardcastle
Hi @Natranzow ,
Thanks for posting! Would you be able to upload a sample file and i'll be happy to take a look at it for you.
Many thanks!
Spencer Hardcastle
Manager of Customer Advocacy - Autodesk Fusion
Message 3 of 9
Natranzow
Ive uploaded an example file. For the sake of the example i've modeled the chamfers in the area i wish to chamfer and located the origin in the position the actual part is in. Thanks for taking a look. Apologies for the late reply.
Message 4 of 9
Ketherton21
is your machine 4 axis? or 3+1?
Message 5 of 9
engineguy
@Natranzow
You can create a single line toolpath in Rotary using "Circular" and placing both the "Front" and "Back" modes to the same position
Hope that helped a little 🙂
Stay Safe
Regards
Rob
Message 6 of 9
daniel_lyall
@Natranzow have a look at the attached model, it's close.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 7 of 9
Natranzow
@spencer.hardcastle
Did you happen to look at the file yet? No solution posted has worked yet.
Message 8 of 9
I preffer Blend over Flow because it gives more uniform pattern over curved surfaces.
Message 9 of 9
engineguy
@Natranzow
Well, all I have is a very ugly workaround, about the ugliest I have ever seen but it does work if you want to try it out 🙂 🙂 🙂
File attached.
Stay Safe
Regards
Rob
