Announcements
Right angle head attachment
Is there a way to use a right angle head attachment with Fusion cam?
Thank you in advance.
LibertyMachine
There are no "built in" solutions to speak of. It is doable, but it would require a fair amount of post processor editing, as the axis would need to be changed and drill cycles would be long hand, again, with axis substitution (Z becomes X or Y, vice versa)
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Lonnie.Cady
Why would you need to use axis substitution?  I once worked at a shop that did it that way but when I went into programming we did it with G17, G18, G19 and got away from axis substitution.  This was for a right angle head on a large VTL.
LibertyMachine
That's....a good point. Perhaps I'm overthinking it. I was looking at it from the Fusion side of things and not the machine. I'll try to test that out if I have time today.
Seth Madore
