Fusion Manufacture
Rewind of Machine Haas UMC 750
4 REPLIES 4
marcjwoodjr
442 Views, 4 Replies
We have a haas umc 750. I am trying to use the flow tool path and receive a rewind error when I try to post. I've downloaded the latest post and also turned on the rewind encoder function listed on the post editing area. Anyone found a solution to this or know what I'm doing wrong?
Screen shot of the error attached.
4 REPLIES 4
KrupalVala
in reply to: marcjwoodjr
Hi @marcjwoodjr ,
Enable the rewind function in the .CPS post processor file. To do so, you will need to change the following line of code as a True:
var performRewinds = true;
Save and test it carefully.
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
marcjwoodjr
in reply to: KrupalVala
This was much needed. Thank you. I finally just got to this it appears to work.
KrupalVala
Hi @marcjwoodjr ,
Thanks your for your feedback.
IF my answer solve your question, could you please click the "Accept Solution" button ? This helps everyone find answers more quickly!
Krupal Vala
mario4QRGL
hello you all, how do i get to , ** Enable the rewind function in the .CPS post processor file, to perform
