I'm experimenting with lithophanes. I used an online lithophane converter (itslitho.com) to make my STL file. I've imported that into Fusion 360 without issue. It's the correct size (apprx 75x75mm, 3mm thick) for my acrylic stock. I'm using parallel 3D milling, and my outputted gcode looks great in my sender (using bCNC). The only trouble is that when I run the program, my mill immediately retracts so high, it trips the Z safety switch every time.
I can't imagine what I did differently today, because yesterday's test runs worked fine. I learned then, I'd like to try with a tighter step-over. Today, no matter what I do, I can't run a single program because of the retract height. In Fusion 360, my heights are configured relative to my 3mm stock height, and I've set my retract height only 12mm above my stock, which is well within the limits of my machine. Even if I set it to only 5mm above my stock, this problem persists.
Any thoughts?
