Fusion Manufacture
retract adjustment between work offsets while machining multiple parts
4 REPLIES 4
patrick.latham1
716 Views, 4 Replies
I need to remove or adjust the Z retract function between changing work offsets while doing using multiple work offsets.  Has anyone figured out how to do this or to tell it to stay down and retract only to a certain height.
I am machining multiple parts use a different work offset for each part.  I am currently probing each part.  I have it optimized by operation to cut the same operation on each part before changing tools, but between each part my Z axis retracts to home.  As we are doing a lot of parts and have multiple tool changes, having it retract about an inch or 2 instead of going all the way to the tool change point between parts would save a lot of time.
"I'm using a HAAS machine
Is there any way control this in fusion without typing it in manually?
4 REPLIES 4
in reply to: patrick.latham1
There are not many options when you use multiple work offsets.  The only way I know of to keep the tool down is to use one work offset and cam multiple parts in one setup.  This is a good option if you are cutting multiple parts from a single piece of stock, but will greatly increase your programming time.  If I were you I would just hand edit the code.
This is a post processor edit. I can help this evening.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
morgantooldie
in reply to: Steinwerks
Could you help me with this? Machine is a Haas Tm-1
HAMMENG
did you have any luck with this? i could nut it out myself (have edited my posts a fair bit already) but if someone has already done it that would be awesome. I'd especially like a post property where I could change it from say "full retract OR set z height"
