Announcements
Rest machinning "Cannot Verify stock transfer" (Pulling my hair)
kris.chlapek
kris.chlapek
Hiya
So, I`m trying to do rest machinning as per this tutorial. https://www.youtube.com/watch?v=_QlzH8SzKkA
However, i get the "Cannot verify if the stock was transfered", i click Yes, i can see the remaining stock on the second setup, but i cannot get it machines as the " original stock" remains in the first vice.
I don`t know what to do anymore with this.
Thanks for any help.
kris.chlapek
Just as a note, this used to work last year. I just dug out an old file that I did,but when I try to edit the old file and place model again the stock no longer transfers, so looks like something has changed in the process.
mattdlr89
This is a similar problem to your other thread. If you are using copies of components in the setup make sure you select it at the component level rather than selecting the body of each.
kris.chlapek
Thanks god there a smarter people than I am. I cannot beleive it is so simple, i`ve spent 6h on this yesterday! Thanks
