Fusion Manufacture
Rest Machining and "Manual NC". Is there a way to show the stock "machining progress" after the Manual NC?
3 REPLIES 3
matt.hapgood
161 Views, 3 Replies
I am trying to some Manual NC comments and "Stops" to allow me to install and move some hold-down bolts during a machining process. Unfortunately, when I insert the Manual NC lines into the setup I lose the ability to view the rest machining on the stock.
Is there a simple workaround?
Matt
3 REPLIES 3
seth.madore
in reply to: matt.hapgood
Hmm, I regularly use Manual NC and don't have those issues:
Any chance you could share your file so we can investigate and see what's going wrong?
Seth Madore
matt.hapgood
I am embarrassed... it wasn't the Manual NC lines.  It was a change in the model (those two tubes at the top, which are for hold-down bolts in the stock.  I added those to the model and that caused the rest machining to not work.  I've resolved it.  Thank you for your quick reply.
seth.madore
Glad you got it solved!
Seth Madore
