Fusion Manufacture
Rename toolpath operations
4 REPLIES 4
Bnuno608
262 Views, 4 Replies
In the company we still work with single NC programs.
Each toolpath has a NC file.
In powermill we can rename all toolpath at once
With macro.
I want to achieve some thing like
Operation-01
Operation-02
Operation-03
Operation-xx
The same aplies to NC program.
I need to the rename NC program
Another question?
Is it possible to select all toolpaths and create One NC program for each toolpath selected?
Thanks on advance
4 REPLIES 4
seth.madore
in reply to: Bnuno608
For the renaming, this is likely possible using the API and a script/addin. That's about the extent of what I can suggest and anything more is beyond my knowledge.
As for the "select all toolpath and create one NC Program", the answer is you certainly can do this.
Seth Madore
programming2C78B
I belive OP wants ONE NC code PER tool(path), but done automatically from selecting the setup.
I would just use a shortcut, select T1, CTRL P, click ok. Select T2, CTRL P, change name to 002, click ok. etc
Please click "Accept Solution" if what I wrote solved your issue!
dames123
in reply to: seth.madore
I think he's asking for this functionality from PowerMILL. I have the same question. I'm sure someone can write a script. We just need to be nudged in the right direction.
