Fusion Manufacture
removing Z/F codes in G92 thread cycle
3 REPLIES 3
boute_bram
195 Views, 3 Replies
Can anybody help me remove the Z-coordinate an Feed output from this thread cycle?
Many thanks in advance.
3 REPLIES 3
Arun.rs
in reply to: boute_bram
Hi @boute_bram
You can give '//' infront of 'zOutput.reset();'  as shown below, this will omit the redundant Z values.
  switch (cycleType) {
  case "thread-turning":
    if (getProperty("useSimpleThread") ||
      (hasParameter("operation:doMultipleThreads") && (getParameter("operation:doMultipleThreads") != 0)) ||
      (hasParameter("operation:infeedMode") && (getParameter("operation:infeedMode") != "constant"))) {
      var r = -cycle.incrementalX; // positive if taper goes down - delta radius
      moveToThreadStart(x, y, z);
      xOutput.reset();
     // zOutput.reset();
      writeBlock(
        gMotionModal.format(92),
        xOutput.format(x),
        yOutput.format(y),
        zOutput.format(z),
        conditional(zFormat.isSignificant(r), g92ROutput.format(r)),
        pitchOutput.format(cycle.pitch)
Regards
Arun.RS
Technical Consultant - Post Processor
boute_bram
in reply to: Arun.rs
It works, thank you very much @Arun.rs .
Any ideas to get rid of the pitch value?
Arun.rs
Hi @boute_bram
Pitch output is forced in the post. If you don't want to output the pitch output redundant then,
Change this:
var pitchOutput = createVariable({prefix:"F", force:true}, pitchFormat);
To this :
var pitchOutput = createVariable({prefix:"F", force:false}, pitchFormat);
Regards
Arun.RS
