- Mute
- Permalink
- Report
Hello all, I recently bought a new Syil X5 CNC machine that runs Mach 3. I have created some calibration components to machine and see what the initial accuracy and ornamental surface finish is like.
The Problem:
Features machined directly along the X or Y axes have an impeccably brilliant surface finish, though, features that are machined simultaneously along the X and Y axes do not. There are large noticeable cusps in these areas. These areas include radii and angled walls (which have various X and Y cardinal influences).
Attempted Solutions, Hypotheses and Results:
Backlash issue along X or Y axes? Not the case. Both axes measured with a Mitutoyo tenths indicator by appropriate metrological protocol. Resulting backlash values of equal to or less than two tenths of a thou (0.0002 inches). Additionally, the respective axes were jogged in incriments of 0.0001 inches from 0 to 0.001 and back to 0 with less than 0.0002 loss. Moreover, the axes were physically pulled/pushed to test for backlash. (Yes, I know this level of performance is rather high for a machine like this).
Tolerance Issue in Fusion 360 Toolpath? Not likely. At first tolerance was set to a reasonable 0.002 (smoothing disabled during all tests). Things did not change when tolerance was eventually decreased to 0.0001.
Cusps Setting in Fusion 360? No. I tried all combinations including machine cusps (with values set at 0) to no avail.
Fusion 360 Mach 3 Post Processor Linearization Issue? Does not seem like it. I changed the linearization setting to 0.0001 instead of the default 0.002 and did not notice any changes in the machined work-piece.
(Pictures Below. Red Indicates Problem Areas, Blue Indicates Good Areas).
Final Finishing Pass. Zero Stock to Leave.
3D Roughing. 0.007 Radial Stock to Leave.
Red Problem Area. Blue Good Area.
