Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Re: Using an end brush with Fusion 360
2 REPLIES 2
indeliblesteve
322 Views, 2 Replies
Ah, sorry, wrong forum.
Tags (1)
2 REPLIES 2
I'm working on wooden 3D contour maps and my finishing pass uses a scallop tool path with a 1/32 radius but it leaves small tool marks.  I can't really clean it all up by hand so I've been thinking about generating another tool path using a 1/4" end brush.
Does anyone have any experience using CNC end brushes in Fusion 360.
Do I just assume it's a 1/4" end mill?  Feels like that wouldn't get into the smaller areas.
Thanks for any advice.
I've not used that exact brand, but I have used the Xebec Cross-Hole style, which are designed to "splay" out. In your case, yes, you would consider it as a 1/4" endmill, but I'm not sure what realistic improvements you will see, if the goal is to reduce cycle time. It seems better that you swap to a larger ball endmill and do your finishing that way. What size tools are you using, aside from a bull endmill with R.032 rads (or was that a ball endmill?)
Seth Madore
