Fusion Manufacture
Rapid Collisions in Adaptive Clearing
10 REPLIES 10
Message 1 of 11
lexaedsall
210 Views, 10 Replies
I am using Fusion360 for milling wood pieces - the pieces are somewhat irregular and modeled in Rhino.  I am having a hard time eliminating rapid collisions with stock on the adaptive clearing toolpaths.  I have searched the forums and found ways to reduce, but not eliminate these collisions.  It generally seems it would work if the path would just take smaller passes, but I don't know how to force that.  Alternatively, is there an alternative toolpath to use first to clear the way for adaptive?  This is coming up repeatedly for me - one example is in the first adaptive pass of setup2 in the attached.  https://a360.co/45uzLGM
10 REPLIES 10
Message 2 of 11
We can't see anything from that link.
Ensure you are properly defining the Stock Contours and everything should be ok. Use 3D adaptive when possible.
Please click "Accept Solution" if what I wrote solved your issue!
Message 3 of 11
seth.madore
in reply to: lexaedsall
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
Message 4 of 11
lexaedsall
Thanks very much - does this attachment work?  I am using 3D adaptive - are stock contours relevant for that?  I'm new so not sure how they fit in.  Thanks!
Tags (1)
Message 5 of 11
lexaedsall
in reply to: seth.madore
Yes - thank you - here it is
Message 6 of 11
lexaedsall
I posted a little earlier about rapid collisions on a 3d adaptive toolpath.  I am reposting with some screenshots and the file to give a little more information - one screenshot shows where I am getting the collision, and one shows the piece in rhino.  (This piece is relatively flat, so I just have one collision.  I have had more collisions I have not been able to resolve with pieces that angle more sharply into the stock.)  Thanks for any advice!
Message 7 of 11
seth.madore
I would start with a 2D Contour (with Ramp and Tabs turned on):
We can then make some tweaks to the (2x) 3D Adaptive toolpaths and end up with only one small collision:
Seth Madore
Message 8 of 11
seth.madore
If it's the same issues as the prior thread you started, it would be best to keep them in one thread
Seth Madore
Message 9 of 11
lexaedsall
thanks so much - I really appreciate it.  What are the types of tweaks that can help with these collisions?  I have had greater numbers in other files.
Message 10 of 11
seth.madore
The 2D Contour to clear around the outside helped a great deal. After that, I reduced the Max Stay Down and also changed it to Full Retraction instead of Minimum.
Seth Madore
Message 11 of 11
lexaedsall
great - thank you so much!
