Fusion Manufacture
Rapid Collision with Stock
4 REPLIES 4
enzoadorno1
124 Views, 4 Replies
image_2023-09-20_183212902.pngI'm new to Fusion and I'm getting rapid collisions with stock only on one side of this part...
4 REPLIES 4
enzoadorno1
in reply to: enzoadorno1
Here is other photo. Tool is plunging instead of cutting row by rowimage_2023-09-20_185040305.png
a.laasW8M6T
I looks like you are probably incorrectly using stock contour selections, but its hard to tell without seeing the file.
Can you upload here?
Go  to File>Export>save as
enzoadorno1
I've tried all kinds of variations, some with fly cutters, some with end mills, some with stock contours, some without. Keeps diving into the piece to start cut at random points. Here is the file.
a.laasW8M6T
Hey, so the problem was that rest machining was turned off.
Even if it is the first operation you still need the rest machining on and set to "From setup Stock"
I switched to the 1/2" endmill as the toolholder on the other tool was colliding with the part.
Also turned on both ways as for soft materials this should give a good time savings
