Fusion Manufacture
random x axis move in Rotary 4th axis toolpath
1 REPLY 1
Ariel
121 Views, 1 Reply
The picture is quite self explanatory really.
Circular rotary pass
Climb milling only
Tolerance at .01mm
No smoothing because the toolpath size is excessive for Pre-NGC Haas
Clearance set at 2mm
full retraction
no lead in/out - even if there was it makes no difference
no tool clearance selected - same as above
Surfaces selected for machining - changes to surface clearance makes no difference
Any help would be appreciated
Cheer,s
1 REPLY 1
seth.madore
in reply to: Ariel
Sorry if we missed this thread. I've sent you a PM
Seth Madore
