Fusion Manufacture
Random code on the Chamfer
1 REPLY 1
ian1196
112 Views, 1 Reply
I have a 24" steel disc that I am using as a trencher to roll a trench in the earth. It was a rainy day project. Attached is a CAD of the disc. I have a clean hole in the center as a reference and I cut an edge on the disc in 4 operations. Shown is one operation to cut over 180 degrees on a side. I noticed that on the chamfer, there are semi random bumps. See the CAD. The CAD is a simple circle that was extruded and chamfered. Does anyone know why the chamfer has  those bumps and would explain it to the rest of us?
1 REPLY 1
a.laasW8M6T
in reply to: ian1196
Hi
The issue is with the additional allowance being too large.
it should only be -0.0002 ish not -0.2
the easiest way to do this is to enter - tolerance into the field:
