- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
Looking for some help on the correct strategy to machine the slot in the attached f3d file.
The slot travels around 90 Degrees but also has a ramped bottom. A ball bearing would be used to travel in the slot so i wanted to rough it out and then finish with a single cleanup pass using a 10mm Ball Nose Cutter for the curved base.
Any ideas? I am struggling to find a strategy that will stay parallel to the slot and also follow the ramped base.
Regards Adam
