Ramp toolpath doesn't keep contact with the part
stefanoprato8
stefanoprato8
Greetings,
I'm trying to rough mill the outside of my part with an high feed end mill. I would like for the tool to maintain contact with the part to avoid entering and exiting the cut. I tried to use a ramp toolpath but no matter which parameter I change (contact point, tool containment, linking etc.) the tool always exit and reenter cut at the corners. I tried to eliminate the modelled fillets at the corner but nothing changed; changing lead-in and lead-out has some effect but not the desired one and I don't understand the logic of it.
Using 2D contour with the ramp option does work but it doesn't machine the steep part (left side of the model).
Is there a way to fix this? the part seems pretty simple to me.Autodesk Fusion 01_05_2024 10_55_12.pngAutodesk Fusion 01_05_2024 10_48_16.pngAutodesk Fusion 01_05_2024 10_48_25.pngAutodesk Fusion 01_05_2024 10_48_36.png
programming2C78B
you can try disabling lead ins and offsetting your machining boundary.
Please click "Accept Solution" if what I wrote solved your issue!
oleg.tikhomirov
Hi @stefanoprato8
Thanks for feedback. I think @programming2C78B is right and trimming is caused by machining boundaries. Could you please try the following options?
Oleg Tikhomirov
Software Engineer
