Ramp on multiple depths
gastontaiba
gastontaiba
I´m having an issue when using ramp entry and multiple depths, I want to use a 10 deg angle ramp, but it only changes the angle on the first pass, on the second pass the angle is still 2 deg. Anyone else having this problem?
Thank You.
Gaston.
HughesTooling
Someone else reported this awhile ago, the workaround was to set the Maximum Ramp Step to a really big number. As you've set multiple depths you should be safe with the Max Step set high.
Mark
Mark Hughes
Owner, Hughes Tooling
kbpav
will this problem be fixed?
vandyckaj
This is super annoying. Setting the max ramp step down to like 100 inches is a workaround. But... They should at a minimum fix it so the ramp settings apply globally to the step downs in the contour toolpath, or if they wanted to take it a step further, what would be even more awesome is to just have a separate ramp settings dialogue in the step down toolpath portion. That way one could have an entry ramp set one way, and then a different ramp parameter after initial step down.
