Fusion Manufacture
Ramp cycle long generation times
1 REPLY 1
gordonjlburnett
99 Views, 1 Reply
Hi looking for any tips on fixing long generation times for Ramp.
had a job with 430 to 432 mm bore, over a length of 1150mm, can use bore cycle to do the taper for big to small, and the compute is complete before accepting the window, to do the other side big to small (from half way) I needed Ramp and a slot mill with radius tips , so used the same tool for both.
The issue is the time difference and time after the generation says 100% for the green icon to turn up.
I did a test on the whole 1150mm and
bore 80sec to complete in-process stock generation
ramp 300 sec for toolpath generation (100% cpu) then wait at 35% for the Cam Kernel to work , the clock in the setup gets stuck at 25% for a long time, even though the toolpath is complete.
1 REPLY 1
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
