Radial stock using trace.
There is a raidial stock check box while using tracing but it doesn't do anything. Is it possible to use this feature? The axial stock works but why is the radial stock even an option?
Brian
hansun_zhu
HI Brian,
Did you mean the radial stock to leave?
Hansun
fonsecr
The radial stock to leave is used when you choose Sideways Left and Right compensation. But it is not used when using the Center compensation (which is the default).
We will see if we can get the radial stock grayed out when Center is active to avoid confusion.
Thanks.
René Fonseca
Software Architect
tnfjield
To revive an old thread, I just found out over the last couple of days that radial stock to leave is ignored when sideways compensation is set to center.
This really should be greyed out or disabled when set to center to avoid confusion (and wasting time with trial and error).
mathew.hutton
Hi @tnfjield @Anonymous
I'll submit a ticket to development on this so that the option is either removed or grayed out if tool center compensation is selected.
Cheers
Mat
Mathew Hutton
Manufacturing Specialist
