Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Radial and axial grooving
weber_dominic
weber_dominic
I'm trying to groove this round shape with a round insert.
Unfortunately it only grooves the axial part but not the radial as well.
Does anybody know how i can solve this so the tool goes all around this sort of quarter groove?
seth.madore
No, we cannot do that with anything currently in the general publics version of Fusion.
However.....we do have a toolpath that you could use with success, but it's in the Insider version..
You need to be a member of the Insider Program to access that feature. Membership is free, but it does involve an application process. You can apply here: https://feedback.autodesk.com/key/Fusion360Insider
The toolpath is called "Trace", and this is the result:
(view in My Videos)
It's a Sketch based toolpath and is not model aware (it will link thru the part if it wants). Collisions will show in Simulation, so it's a matter of tweaking it as needed. Think of it as "the toolpath of last resort" when our other offerings fail.
Seth Madore
weber_dominic
Perfect that worked! Thank you Seth!
seth.madore
Oh, you're a member of Insider?
Seth Madore
TrahTibidoh
Такая возможность есть. Однако точка трассировки режущей кромки инструмента смещается на угол поворота фрезы. Разработчики долго не могли решить эту проблему.
seth.madore
Yes, the old "Turning Groove" will also work
Seth Madore
