Fusion Manufacture
"Warning: Tool diameter is larger than the maximum diameter supported for tools in this machine."
3 REPLIES 3
tom_marttila
140 Views, 3 Replies
My goal is to cut slots for Lamello joining biscuits by using a slot cutting bit (Fraiser 118.040.8D), image below.
I added this bit into my tool library.
I have also created a machine into my machine library. I did this by entering the relevant configuration and parameters into the Fusion 360 configurator for a 3-axis milling machine and by specifying the post processor. This represents well the actual machine that I have.
I have now modeled a test body with a slot for a Lamello biscuit. The slot is 60 mm long and 4 mm high with a 100 mm radius at the back, image below.
2D Contour seems to work well for cutting the slot, simulation results are fine. But a warning stating "Warning: Tool diameter is larger than the maximum diameter supported for tools in this machine." is shown.
Where is the maximum tool diameter for the machine specified? I have not entered it, and I cannot find it.
Is 2D Contour the best option for cutting these slots?
3 REPLIES 3
You can specify maximum tool diameter on the head in kinematics tab of machine definition dialog:
Viacheslav Shapilov
Developer Technical Services
Autodesk Developer Network
tom_marttila
in reply to: tom_marttila
Thanks. There it was!
Thanks!
