Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
"Post processor not compatible with machine simulation." Trying to machine simulate with 4th axis.
2 REPLIES 2
rhigdonL4LXL
253 Views, 2 Replies
Spent all day in machine builder trying to get a 2012 (pre-NGC) Haas VF-2SSYT + 4th Axis machine simulation working. But getting an error message:
"Post processor not compatible with machine simulation. Simulating without a machine"
The post works with the machine & 4th, it's the generic HAAS-A-axis (pre-NGC) from autodesk library.
2 REPLIES 2
a.laasW8M6T
in reply to: rhigdonL4LXL
Hi
For the post processor just use the Pre NGC post, not the Pre NGC with a axis and it works fine.
You only need the pre NGC with a axis post if you aren't using a machine configuration.
Now it simulates fine(except the Pcool is hitting the rotary):
It also appears that there are a bunch of hidden fasteners off to the right that you need to get rid of in your machine model
rhigdonL4LXL
Thank you so much! The simulation is working great now. Finally! Crashes into the rotary was my main motivation.
Technology Administrators
