Fusion Manufacture
Quick - 2D Contour Question
2 REPLIES 2
richardsalzman
82 Views, 2 Replies
I am machining a small block where each face is machined .001 deeper than the preceding face.
The initial adaptive clearing path left .005 material remaining for the contour path.  I wanted the contour path to remove .004 then the final .001.   I am confused as to why I had to select 2 for the number of finishing paths.  I thought I would only indicate "1" for the number of finishing paths.  Am I missing something?
I am trying to machine this as precisely as possible on a hobbyist machine.  Is there any other trick I can do to improve accuracy?
Thanks... Richard
2 REPLIES 2
That's because you don't have "Roughing Passes" turned on. If you were to turn that on, you would get the default single pass, but then you would also get a second pass that would refer to your Stepover:
Seth Madore
Thanks ... That makes sense.
